The message indicates the failure in creating or removing an entry in the PortEncoding table in IOB. Lower the severity to narrow the cause of failures. The cause could be in the PSI librar, the conduit pipe to the given slot, or the low on memory in the system.
Retry the configuration so that the entry is re-created or removed in the PortEncoding table in X11 associated to the given slot and port.
Debug-Data
Failed to update portEncoding table for port %slot%:%port% in %vlanName% associated to %isidName%.
| Name | Type |
| slot | Slot |
| port | Port |
| vlanName | String |
| isidName | String |
